In the User Manual (page 14), it is recommended that M3 x 20mm screws be used for mounting the router to the wall. This was very helpful but I'd like to see the type of screw head added to the screw ...
schumaku
Nov 23, 2023Guru - Experienced User
Metric threads for mounting anything into a wall? Wonder what kind of inserts or dowels they have in mind when putting up the specifications for a M3x20 8-/
Measuring the distance between two holes should not be very difficult in the do-it-yourself world. Sure, more critical are the heads, because of the space is limited. Pan-head-like screws should be fine, indeed.
