Please add a page to auto display the MAC address of all the devices attached to the switch.
By default, each port should be disabled, and I will enable it if I want to allow the attached device to access the network.
It will be easier to set up ACL by Mac. No typing MAC addresses no rules to setup.
Of course if you want to setup ACL by rules it should disable or override this page.
But most network setups will really benefit from this simple way of controlling rogue devices and protecting unsupervised data ports.
Consider that this feature will give Netgear and advantage over the competition.
I will change all my network switches for those that have a feature like this.
No CommentsBe the first to comment
