The fan speed is fixed to 4000 RPM, can this be changed to smart as the switch is not installed in a server cabinet. the tempeture is als stable. i think it should ajust itself according toe what th...
StevenTibosch
Nov 22, 2024Follower
Hi,
I have the same issue with the MS324TXUP its WAAAAAAAY too loud. Very annoying when used in residential buildings
