Hello,
We purchased the BR500 mainly for it's VPN functionality and the offer we got. But we are missing a feature which is crucial for any IT testing company.
This is why I'm sending you this request to add the option to setup port forwarding on multiple WAN addresses.
The unit can handle a 255.255.255.248 mask on the WAN side, but there is no way in the Port forwarding to tell the device it should listen beyond it's primary address.
Can you please fix this?
With regards,
Wil...
ADI Global
Netgear Distributor
No CommentsBe the first to comment
