MSMSP01
Sep 13, 2021Initiate
Feature Request in Insight Portal
Can you consider allowing you to view which License code is assigned to which organisation and be able so assign specific liceses codes to specific organisations. Thanks
schumaku
Sep 13, 2021Guru - Experienced User
This is a good suggetion. It belongs to Insight Pro in my understanding. In case you don't have access to Insight Pro (For MSP And VAR Only) request the access via [email protected] .
