gsuk's avatar
gsuk
Follower
Jan 15, 2018
Status:
New Idea
GS105E v2
Hi, the product GS105Ev2. Can the QoS options be changed in firmware to allow the port egress bandwidth to be specified differently? Currently the selection is in multiples of 512Kbps, but I require multiples of 1/10Mbps?
Thanks.
2 Comments
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi gsuk,
    Welcome to our community!
    As per checking the manual, you can set a rate from 512 Kbit/s to 512 Mbit/s. By default, no limit is set. Prosafe plus switches are limited in terms of functionality unlike the smart switches. You may check the GS110T and the instructions on how to configure QOS for smart switches.
  • JohnC_V's avatar
    JohnC_V
    gsuk,
    I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
