robertpankrath's avatar
Dec 18, 2018
Status:
New Idea
GS108Ev3 Cannot set VLAN for management interface
Dear developers,
it would be great to be able to configure VLAN for management only.
See also this thread:
https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS108Ev3-Cannot-set-VLAN-for-management-interface/td-p/971240
If that is too much work could you please implement the possibility to disable Webif with Plus Utility?
Reason for this is to get rid of this limitation /unpleasant behaviour:
"To support WEB GUI, all HTTP packets are forwarded to the embedded CPU.  With Flow Control enabled, throughput will be impacted if the rate is higher than the CPU can handle."
or at least having a workaround to avoid it!
Kind Regards
Robert Pankrath
Berlin Germany
1 Comment
  • another possibility would be making WEB UI Port/Proto changeable to a different one
