Shocklog
Oct 26, 2016Initiate
IPV6 in load balancing mode on SRX5308
If you have more them one internet connect you cannot use IPV6, because IPV6 is only available in Primary WAN Mode. Also you lose all you’re settings when you change from Load Balancing to Primary WA...
Shocklog
Nov 02, 2016Initiate
Essentially if Netgear have no plans to implement IPV6 in Load Balancing mode on the SR5308, then organisations with more than 1 internet connection cannot use this product. Which is a shame because otherwise it is a very good reliable product?
