ikimbleygrt
Sep 30, 2020Follower
limited admin options on the BR200
I have a couple issues with this BR200 that I installed today at a customer site. 1) no remote administration option: I understand that the intention is to use insight, but I would still like to use...
david324
Feb 12, 2021Follower
The NETGEAR genie application also permits you set up cloud access that can attest you to control your Netgear switch's key settings by implication from an iOS or Android contraption. For empowering inaccessible access, you should be connected with your Netgear switch locally. To gain ability with the best approach to instigate inaccessible access, you should go to the web address routerlogin.net from your upheld web program.
