cp42's avatar
cp42
Tutor
Jan 02, 2017
M4100: scheduled config save via encrypted connection (needs telnet up to now..)
Hello everybody,
we would like to use NMS300 to save the config of our 40 Netgear Switches (M4100 series, different models) automatically every night, but this requires telnet to be enabled on all switches (confirmed by Netgear Expert Bruce_G: https://community.netgear.com/t5/Managed-Switches/NMS300-config-backup-with-telnet-disabled/m-p/1161992/thread-id/2682#M2753)
I think that transmitting a password for administrative access in cleartext over the network isn't best practice, especially for a product which claims to be enterprise ready.
Would you please implement an option for a scheduled config saving and other mass actions like firmware update for all switches via an encrypted conection? It should be possible to disable telnet on the switches without disabling any funcionality (apart from logging in via telnet of course..)  ;-)
Thanks in advance!
Kind Regards
Christoph Peus
2 Comments
  • Hi Netgear,
    The ability to auto-backup config file with secure protocols should be available for all kind of switches, we need it too as using telnet is not secure at all.
    Regards
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi cp42,
    Gave kudos to this post. :)
    DaneA
    NETGEAR Community Team
