ViperNT's avatar
ViperNT
Follower
Sep 11, 2017
Status:
New Idea
make it possible to go up one level in cli configuration of WNDAP620
it would be cool to be able to go up one level during cli configuration of said AP. Like in Ciscos IOS, if you are in "configure terminal" or in an "interface" you should be able to go up one config level to be able to choose a different configuration item.
At the moment you're "stuck" in the lower level and need to reconnect (and relogin) to configure the AP further
1 Comment
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi ViperNT,
    Welcome to the community! :)
    The development team will be reviewing your post and assess it.  Be reminded that the more kudos given by community members to your feature request will help as the development team will be reviewing the post that has the most kudos and might be considered.
    DaneA
    NETGEAR Community Team
