SRR60 - Using the Guest band I am able to set a suitable duration limitations for our active Wifi for visitors. We have a need to set the time duration more incrementally. As it stands, the options a...
DaneA
May 07, 2019NETGEAR Employee Retired
Hi AllanA,
Thank you for posting this idea. :) The Orbi Pro development team will be reviewing this.
Be reminded that the more kudos given by community members to your feature request will help as the development team will be reviewing the post that has the most kudos and might be considered to be implemented.
DaneA
NETGEAR Community Team
