Hello:
The GS105PE switch is a great idea and potential problem solver. Unfortunately, due to one design flaw, it is only "almost" useful.
There are a few different switches that support...
Iruwen
Mar 13, 2018Aspirant
Has this been resolved? The GS105PE would perfect for our use case if it was designed reasonably, we need to power class 2 devices and devices that don't identify as class 2 but use 3W max as well. With the issue described, this doesn't work. It would be sufficient if the power sourcing ports could be configured to assume a specific power class if none is given. I guess even the GSS108EPP can do that (at least the data sheet says "User-defined PoE power limit per port (override detected Class)").
