Hello:
The GS105PE switch is a great idea and potential problem solver. Unfortunately, due to one design flaw, it is only "almost" useful.
There are a few different switches that support...
DaneA
Apr 05, 2018NETGEAR Employee Retired
Is your GS105PE switch already updated to the latest firmware version? If not yet, I suggest you to try to update the firmware to the latest v1.5.0.5. You can download it here. Be reminded to perform a factory reset after updating the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version. Then, check if same problem occurs.
DaneA
NETGEAR Community Team
