Hello:
The GS105PE switch is a great idea and potential problem solver. Unfortunately, due to one design flaw, it is only "almost" useful.
There are a few different switches that support...
cdoublejj
May 03, 2019Aspirant
I found that the D Link DGS-1100-05PD allows PoE Class override! So you can manually classify the wattage for each of the 2 devices! It's not a netgear but, it also has a Web GUI. I already filed for retunr on newegg for my GS105PE and i'll just get the DLINK, it's also cheaper too. Sorry netgear unless you roll out firmware that allows manual PoE override this thing is almost usefull and almost fales advertising. I like your products but, i'm not even sure if a netgear AP would proepr clissfie it's self to run off the GS105PE AND run an IP camera.
