chrimu's avatar
chrimu
Follower
Jan 26, 2019
Status:
New Idea
Port security essential for outdoor PoE camera connection.
Hi, As a common use-case tor these PoE switches is CCTV with connections outdoors, may I suggest to add a feature in the firmware that prevents these outdoor ports to be used with devices other than the intended camera? Would port-security, ie. binding to a given MAC address, be a right step in that direction? Or did I overlook a feature that already does this now? I'm by far not an expert ;-) Kind regards, C.
No CommentsBe the first to comment
