thescouselander
Jan 18, 2024Follower
Status:
New Idea
Reset DCHP Warning on Power Light After Fault has cleared
WAX214 Firmware Version: V1.0.2.3 This unit displays a blinking amber power light if contact with the DHPC service is lost. The problem is the power light continues to blink amber even if the D...
thescouselander
Jan 22, 2024Follower
That's not quite correct as far as I know.
As found on page 9 in the product manual here Essentials WiFi 6 AX1800 Dual Band Access Point Model WAX214v2 User Manual (netgear.com)
"Blinking amber: The firmware is being updated, or the AP cannot detect a DHCP server. "
The situation I have encountered is that my router occasionally reboots during an upgrade or whatever reason and that sets off the blinking amber light. After that AP seems to work normally and DHCP services are available yet the blinking amber lights remains and I have confirmed this is not because of an upgrade or anything else.
