thescouselander
Jan 18, 2024Follower
Status:
New Idea
Reset DCHP Warning on Power Light After Fault has cleared
WAX214 Firmware Version: V1.0.2.3 This unit displays a blinking amber power light if contact with the DHPC service is lost. The problem is the power light continues to blink amber even if the D...
schumaku
Jan 22, 2024Guru - Experienced User
My comment applies to the WAX214 ... not the WAX214v2. Two different pairs of shoes. The DHCP logic behind is the same however. Appears the WAX214v2 does not properly monitor and track the IP stack DHCP status, and does not update the power LED notification. Must be some oversight on implementation and testing.
