Jonagold1
Jun 14, 2016Follower
SHA-256 signature algorithm for SRX 5308
Need firmware upgrade, if possible, for SRX 5308 to add SHA-256 or higher signature algorithm to meet PCI compliance. If this is not possible I need to know so I can replace hardware with compliant h...
Victor_Work
May 18, 2017Novice
I am in the same situation. I am failing PCI scanning due to weak SHA-1 certificate.
