Dnogu860's avatar
Dnogu860
Follower
Jun 04, 2020
Status:
New Idea
Ssid to clean mapping
Include a SSID to vlan mapping feature rather the just ethernet port to vlan feature. Guest said should be able to be separated from main said with different network as well.
1 Comment
  • schumaku's avatar
    schumaku
    This is only to bridge an additional tagged WAN/Internet VLAN to a LAN/Ethernet port allowing to connect an IPTV media box.
    > SSID to vlan mapping feature ... Guest said should be able to be separated from main said with different network as well.
    Requested many times - answer was always there won't be any VLAN support on the current Orbi Pro SRR60/SRC60 with dedicated VLANs, IP subnets, ...
