100won
Sep 14, 2022Star
[SUGGESTION] SXK80 add reboot schedule feature.
Hi, I see the other brand wifi has feature reboot schedule but sxk80 has no. I suggest add it in.
schumaku
Oct 14, 2022Guru - Experienced User
May I suggest to open a thread, describe the slow-down situation. A moderator should pick-up, offer certain diagnostic process, like collecting diagnostic data or allow Netgear support/engineering a remote diag access, to check what is going on.
