TSpitzmann's avatar
Oct 04, 2022
Status:
New Idea
SXK80 SSIDs and individual radios
Using the SXK80 we should be able to activate the desired radios for each Wireless network configuration individually.
For instance if we want to use Wireless 3 only on 2.4 GHz we want to  be able disable the 5GHz radio for Wireless 3.
Configuration could go similar like this:
<Checkbox> Enable SSID separation for 2.4GHz/5GHz
Wireless 3 Network Name (SSID) : (2.4GHz)
IoT-2.4GHz
<Checkbox> Disable 2.4GHz radio
Wireless 3 Network Name (SSID) : (5GHz)
IoT-5GHz
<Checkbox> Disable 5GHz radio
1 Comment
  • Please find attached a mock-up of a possible configuration implementation...
