The SXR80 v3.3.0.122 does not currently support VLAN's in AP mode. There are settings for it, but it doesn't work. I suggest that VLAN support should work like it does on your smart switches. Add ...
schumaku
Oct 19, 2021Guru - Experienced User
Reads more like a firmware issue than a feature change.
