The SXR80 v3.3.0.122 does not currently support VLAN's in AP mode. There are settings for it, but it doesn't work. I suggest that VLAN support should work like it does on your smart switches. Add ...
schumaku
Oct 20, 2021Guru - Experienced User
Please create a new thread for the Orbi Pro WiFi 6 (different from the one on the "classic" Orbi Pro by design!) in the community.
There is supposed to be much more than the IPTV WAN Bridge VLAN support as we know from the consumer Orbi and the first Orbi Pro generation.
-Kurt
