The SXR80 v3.3.0.122 does not currently support VLAN's in AP mode. There are settings for it, but it doesn't work. I suggest that VLAN support should work like it does on your smart switches. Add ...
Mike16
Oct 20, 2021Follower
The support engineer I spoke to told me to post a message in the Ideas section because the current product doesn't do what I expected, and need it to do. Where exactly do you want me to create a new post, and what is it that you want me to say? There currently isn't any configuration settings related to 802.1q mode, and as far as I can tell it's not supported.
