The SXR80 v3.3.0.122 does not currently support VLAN's in AP mode. There are settings for it, but it doesn't work. I suggest that VLAN support should work like it does on your smart switches. Add ...
schumaku
Oct 26, 2021Guru - Experienced User
eeeMikeee In case this is also in AP mode please progress as BruceGuo advised above.
In case you are facing a different config with router mode and VLANs, consider to open a dedicated thread in the appropriate section, because of the feature request thread is hard to follow up.
