Hi,
I'm using a GS110TP switch with firmware 5.4.2.33.
The HTTPs interface is enabled and working.
The problem is that Firefox is now considering the GUI as unsecured because of TLS 1.0.
There's no way to enable TLS 1.2 and it's a real security problem.
Is it possible to get a new firmware with TLS 1.2 support ?
Regards.
2 Comments
- tdude66Novice
Really hoping this gets addressed soon as well as enabling 4096-bit RSA certificates.
It's a shame that this needs to be a "feature request" instead of part of the standard build. Firefox has just released v74 which does exactly as you described. I'm fairly certain their entire product line has this same problem.
