Please add TLS v1.2 support to the M4100-50G-POE+ switch. The lastest firmware version available for this product is 10.0.2.35 which does not include TLS v1.2 support.
schumaku
Oct 24, 2023Guru - Experienced User
gier wrote:
No current browser supports TLS 1, so HTTPS cannot be used.
Not true, but not very secure either. This is why for example Apple, Google, and Opera (just to mention a few) have removed it from their default browser implementation:
Mozilla Firefox supports TLS 1.0, 1.1, and 1.2 by default. You shouldn't need to make any changes, but you can double-check the settings here if you like:
(1) In a new tab, type or paste about:config in the address bar and press Enter/Return. Click the button promising to be careful.
(2) In the search box above the list, type or paste TLS and pause while the list is filtered
(3) If the security.tls.version.max preference is bolded and "user set" to a value other than 3, right-click > Reset the preference to restore the default value of 3
(4) If the security.tls.version.min preference is bolded and "user set" to a value other than 1, right-click > Reset the preference to restore the default value of 1
The values for these preferences mean:
1 => TLS 1.0 2 => TLS 1.1 3 => TLS 1.2
