JeroenL's avatar
JeroenL
Follower
Apr 02, 2019
Status:
New Idea
Traffic shaping
Please add Traffic Shaping to the BR500.
Let admins prioritise a specific VLAN and limit or garantee a given amount of bandwidth.
For Example:
WAN connection 50Mbps UP/DOWN
VLAN1 contains servers
VLAN2 contains desktops
VLAN3 contains VOIP phones
VLAN4 wifi office
VLAN5 wifi guests
When Windows Updates are downloaded on the servers each day at rondom moments, users complain that connections to Office365 is slow. Also during the day users complain that VOIP calls are disconnected of audio quality suffers.
Sometimes when Guests are using the Wifi, all these problems seem to happen aswell.
Solution:
Create a traffic shaping rule for VLAN1: Set the priority to medium and limit the maximum bandwitdh to 30Mbps shared.
Create a traffic shaping rule for VLAN2: Set the priority to medium no limits
Create a traffic shaping rule for VLAN3: Set the priority to high and set a garanteed bandwitdh of 5Mbps shared.
Create a traffic shaping rule for VLAN4: Set the priority to medium no limits
Create a traffic shaping rule for VLAN5: Set the prioriy to low and limit the maximum bandwitch to 5Mbps per session.
1 Comment
  • On the Netgear Genie application, you need to sign in to your Netgear switch by entering the Netgear switch login chairman secret key that is your login executive mystery key and along these lines tapping on the LOGIN button. Coming about to executing every movement alluded to on the site routerlogin.net the distant permission to the Netgear switch is then empowered.
