Good day Netgear,
I would like to suggest a reset option for the Usage menu in the WC9500 (menu Monitor -> Controller -> Usage).
We are using the Controller in an event/conference building, it would be handy to reset it before every event/conference.
Also the top 2 graphics show an absurd high volume, the legenda says the counter is in TB, then it shows 700.000M on an AP's 2,4 Ghz channel that's online for 115 days. So that's about 4,23 Million TB per minute on 2,4Ghz?
The Usage counter in the menu Monitor -> Summary (most active clients) and in menu Clients is also a bit off, it says Usage(Kbytes) but it is in Bytes like the help file says, and then also 6 digits behind bytes. Clearly a bit too many digits for nowadays internet if you ask me.
Other than that, the controller is great!
No CommentsBe the first to comment
