Hello, I am just starting to work with the AV Line switches. I use them in a concert hall. There is an administrator and many users running the shows. For this, from my point of view, there needs to...
DaneA
Oct 26, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
The M4250 series switches which is the AV (Audio-Video) Line Managed Switches of NETGEAR supports Management VLAN. By default the Management VLAN is VLAN 1 and you can change the Management VLAN to any VLAN you want. Be informed that all switch features such as VLAN, ACL, QoS, etc can be configured using the Main local browser user interface (Main UI) or via the Command Line Interface (CLI).
The M4250 series switches also have an Audio-video local browser user interface (AV UI) which is a web-based management tool that lets you configure and manage audio-video and other types of network profiles remotely using a standard web browser.
To learn more about the specifications of the M4250 series switches, kindly check its data sheet here.
DaneA
NETGEAR Community Team
