CHCarlos's avatar
Sep 26, 2021
Status:
Comments Requested
VPN Certificate Change
Dear Netgear & Orbi Pro Supporter
I recently bought the Orbi SXR80 router and want to use VPN to remotely connect to my office. But I am amazed that the certificates for the connection cannot be changed in the administration interface. VPN is unusable because if the certificate falls into the wrong hands, anyone can connect to my device via VPN. This happens quickly if a cell phone is lost or stolen. Why not add a function to change the certificate? This should be very easy to do. According to the following link, this was apparently already planned:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/Orbi-Pro-SRK60-Revoke-OpenVPN-client-certificate/m-p/2139485
This function is also required by other users:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/How-to-renew-VPN-private-key/m-p/1689399
I urgently ask you to install this function, because without a VPN switched on is a major security problem!
Kind regrads
Carlos
12 Comments
