Iliyas's avatar
Iliyas
Tutor
Sep 07, 2015
Vulnerablity on netgear WNDAP360
Its a new access point which we purchase last month and we had a internal audit the security manager found the below vulnerablity, Can some one please help us to configure the following configurations Netgear WNDAP360 access point.
  • Change Default Simple Network Management Protocol (SNMP) community strings in use
  • Disable SSL 2.0 Deprecated Protocol in Use while login as admin (https:\\netgear AP IP Address)
  • Enable SSL Certificate Chain Contains RSA Keys to 2048 bits in Use while login as admin (https:\\netgear AP IP Address)
  • Disable SSL RC4 Cipher Suites Supported in Use while login as admin (https:\\netgear AP IP Address)
  • If we open (https:\\netgear AP IP address) using https we geting Certificate invalid warning message how do I fix these issues.
Thanks in advance for valuable reply,
M. Muhammed Iliyas.
No CommentsBe the first to comment
