Hi, when I'm using the Guest Network chekbox in Wireless Setting - Access Point, VLAN Isolation is disabled. This is quite limiting in network designs. It would be great if the firmware allowed...
schumaku
Feb 28, 2022Guru - Experienced User
The more I think about this, it appears different features are mixed-up here.
If you want to configure any SSID as a guest network bound to a VLAN you can do it - just do -not- use the guest network feature, and you have the full flexibility and can enable the VLAN isolation*.
*in my opinion a complete odd feature to allow the communication between different VLANs - if somebody want to allow traffic between different VLANs, it would be a router task - not an access point feature.
The guest network feature does add a DHCP server for that network, assinging IP address in the range from 192.168.200.100 to
192.168.200.200 to the guest clients, and add a many2one NAT and does allow IPv4 trafic with the Internet only (to the default gateway only). This feature does however not require yet another VLAN for the guest network already isolated and logially restricted (guest == provide Internet acess only) Unluckily, this does force this VLAN isolation to disabled - completely strange, and of course higly limiting the value of a multi-VLAN design.
