speedman
Sep 04, 2021Follower
WAX610 fast roaming in local management
Hi, I know that the question was allreay asked, but I HAVE to use a local mangement mode, and I wanna use fast roaming. I have a 3 floor house, with a very big garden, so I have 4 APs: - 2...
BrianL
Jul 01, 2024NETGEAR Moderator
Hi speedman,
Welcome to the community!
Unfortunately, the said feature is not available in the local UI (management) mode. You can submit an idea/suggestion here instead.
Kind regards,
BrianL
speedman
Dec 05, 2025Follower
Hi BrianL
Thank you, just did ...
Add fast roaming support on WAX610 with local managment | NETGEAR Communities
