Please remove the requirement to use the https:// protocol for remote admin aonnectonis to the Orbi, given that there is no way to insall an SSL cert in a router. All this does is to force us to cons...
schumaku
Jul 23, 2019Guru - Experienced User
True - integrating Let's Encrypt (to register, install certificate, to renew automatically, ...) would make a great addition.
And then the ability to have to different certificates on the LAN and on the WAN/Internet would make it perfect.
