Wired Backhaul support for WAX610 and WAX214 Access Points
schumaku
Dec 18, 2020Guru - Experienced User
Both the WAX610 and the WAX214 are per se APs to be used on a wired backhaul. different from the WAX610 the 214 does not support multiple SSID to different VLANs legend I have it right. As well, the 610 can be Insightanafed, the 214 can't.
This essentially allows to operate multiple 610 and 214 on the same network, but not with a common "Mesh" environment with sleds roaming - only the Insight managed WAC and WAX have this feature.
Completely unclear to me what.you ask for here.
