Although the AX18000 has VPN support for Pure VPN, how about adding OpenVPN and Wireguard VPN support ? I've had the router for 20 days, I'm content with it's functionality on the whole. That sai...
schumaku
Nov 23, 2023Guru - Experienced User
Completely off topic here. An R6700AX is a basic consumer AX WiFi router, by far not part of Netgear Business Solutions offering. The VPN support is provided for a "dial-up" VPN, allowing to establish a secured OpenVPN based remote access.
No idea why you intend to push all your Internet traffic including streaming, gaming, and much more through a VPN connection. The R6700AX is clearly a budget AX router, has Gigabit Ethernet ports, and could serve a lot of bandwidth, some 800 Mb/s in both directions, on a transparent IP connection, but very unlikely if you want to VPN encrypt everything.
