Hi, For XS724EM current 1.0.1.3 firmware, the port speed options only have "Auto", "Disable" and "100M Full", Is there any way we can set the port speed to specific speed other than 100M? For example...
schumaku
Jan 08, 2022Guru - Experienced User
IEEE has defined the automatic link speed negotiation as mandatory.
For what reason you need to "fix" the link rate?
