Knowledge Base Article
New - CBR750 Firmware Version 4.6.14.8 Released
Security Fixes: 11/25.2025
- Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Download Link:
CBR: https://www.netgear.com/support/product/cbk752
RBS: https://kb.netgear.com/000065416/RBR750-RBS750-Firmware-Version-4-6-14-3
NOTE: Since the CBR version of FW is not fully synced between the CBR and RBS, we can use the RBS FW from the RBK or RBS sites with this FW version for the CBR750.
NOTE: Update the RBS first, then the CBR lastly. I recommend doing a full on factory reset after the FW loads, system is back to ready and a power OFF for 1 minute then back ON has been performed. Use a wired PC and web browser for this. Load the FW on to each RBS web page using the RBS web page, not thru the CBRs web page. Then load the FW lastly on the CBRs web page. Walk thru the setup wizard. You can manually setup the system as well for those who are more experienced with this.
A factory reset maybe needed if problems are encountered:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
NOTE: The Disable Auto Update feature only prevents ANY new FW from being installed if available. This does NOT prevent the system from checking NG services to see if new FW is available. If new FW is available, this will be displayed as a notification to the user on the RBRs web page only. It will be up to the user to upgrade FW or not.
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This article applies to:
Let us know how it works for you in this thread.
Comments have been turned off for this article
