回复
Ruckus R320 eth connect S350 Series problem
casperha
Serial NumberSystem Object OID
5GL18B5F00588
1.3.6.1.4.1.4526.100.4.53
Model NameBoot VersionSoftware Version
GS310TP1.0.0.11.0.0.12
when i plug cat6 cable to ruckus r320 unleashed
just can detect 100 speed full
if i set 1000 and full
also detect same 100 and full
how can i fix it?
Model: GS310TP|NETGEAR® S350 Series 8-Port Gigabit PoE+ Ethernet Smart Managed Pro Switch with 2 SFP Ports
1 条消息(共 16 条)
Weifeng_yang
NETGEAR Expert
回复: Ruckus R320 eth connect S350 Series problem
How long is you cat6 cable?
Is it possible to swap a cable for trial?
Connect with Innovation
2 条消息(共 16 条)
casperha
just 5m...
no too long..
i have change cable also just can detect 100M...
cable pulg in my computer can be 1000M
3 条消息(共 16 条)
Weifeng_yang
NETGEAR Expert
How is the switch port speed if connected with a gigabit computer or another gigabit switch?
Or loop the cable to 2 ports of GS310TP?
4 条消息(共 16 条)
casperha
if connect my notebook can be 1000M SPEED
i have test every port also same problem .... can't up to 1000...
5 条消息(共 16 条)
Weifeng_yang
NETGEAR Expert
Can you contact Hong Kong reseller ?
http://www.winco.com.hk/contact/address.asp
6 条消息(共 16 条)
casperha
i buy in netgear online shop....
7 条消息(共 16 条)
Weifeng_yang
NETGEAR Expert
never mind, reseller can help .
does the AP connect to other POE with 1G well ?
8 条消息(共 16 条)
casperha
yes connect my notebook can be 1000 SPEED
9 条消息(共 16 条)
Weifeng_yang
NETGEAR Expert
So the result are:
R320 - notebook ->1G well
GS310TP - notebook ->1G well
GS310TP - R320 -> 1G failed, 100M only
what is the R320 firmware? does it have a later firmware?
@casperha  已写:
10 条消息(共 16 条)
casperha
(((( correct )))
So the result are:
i have update last R320 firmware
11 条消息(共 16 条)
Weifeng_yang
NETGEAR Expert
Can you attach the tech-support file of GS310TP?
Login to UI of GS310TP, from "Maintenance/Export/HTTP file export" and choose file type as tech-support.
12 条消息(共 16 条)
casperha
FYI
13 条消息(共 16 条)
Weifeng_yang
NETGEAR Expert
From the tech-support file, there are 4 port up with 100M, are all those port connecting with R320 AP?
Port Status Duplex Speed Type
g1 connected a-full a-100M Copper
g2 connected a-full a-100M Copper
g3 connected a-full a-100M Copper
g4 connected a-full a-1000M Copper
g5 connected a-full a-100M Copper
g6 notconnect auto auto Copper
g7 notconnect auto auto Copper
g8 notconnect auto auto Copper
g9 connected a-full a-1000M Fiber
g10 connected a-full a-1000M Fiber
We will file an issue under this GS310TP and escalate to engineering
 team, you may check and update via my.netgear.com
And we still need the detail FW version of R320.
if you can contact HK reseller, they might be able to visit you for onsile analyzing.
14 条消息(共 16 条)
Weifeng_yang
NETGEAR Expert
few more questions from RD. please help to confirm. Thanks
# Have we used the same cable for 3 topologies?
# Can we set switch port to forced 1G and not auto neg? In that case will Rukus AP be up with 1G?
# If Rukus AP is using PoE then can we switch to dedicated DC power supply and check whether it comes up with 1G when auto neg is enabled on switch port?
15 条消息(共 16 条)
Weifeng_yang
NETGEAR Expert
Engineering team hope to know if the link speed is 100M when R320 powered by POE, and link with 1G when using power adapter.
16 条消息(共 16 条)
讨论统计
  • 15 条回复
  • 2430 次查看
  • 0 个奖励
  • 2 交谈中
