× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M1
Paul-1930
Follower
Nighthawk M1
The modem operates, but when, on my browser, I go to "192.168.1.1/index", the username is: 'admin',  then enter the device password but the login fails.  The message in red says 'admin' is incorrect.   Apart from not knowing what it should be, it cannot be changed!!
Nighthawk M1 - MR1100 - Windows 10 - desktop computer- using only LAN cable connection to computer.
How can I fix this login issue?
Model: MR1100| Nighthawk M1
Message 1 of 2
stevesw
NETGEAR Expert
Re: Nighthawk M1
The default admin password is 'admin'.
That should work unless you changed it during the initial setup.
If you can't remember what you changed it to, see p.75 of following doc for details on how to reset your default password:
http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf?cid=wmt_netgear_organic
Steve
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 14386 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
