Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo Baby Cord Length
Reply
Discussion stats
  • 3 Replies
  • 6349 Views
  • 0 Likes
  • 4 In Conversation
mross12
Follower
Follower
How long is the Arlo Baby cord length? I want to make sure that I will be able to mount it pretty high up, and still reach an outlet.
1 ACCEPTED SOLUTION
Accepted Solutions
JamesC
Community Manager
Community Manager
mross12,
Arlo Baby cable length is just under 10 feet.
JamesC
3 REPLIES 3
jguerdat
Guru Guru
Guru
Can't say since it's not out yet.  If it uses the same or similar USB charger as the Pro and Q, you can always buy a longer QUALITY cable (quality is important since cheap ones use small wires, leading to voltage drop and issues).
TomMac
Guru Guru
Guru
No spec, as not release yet,  As a guess, I would venture to say thats it's about the same as the Q cams / Pro cam cord ( btw, uses the same battery as Pro )... about 8 ft... so it may use the same cord / adapter as the Pro
But you can use a usb extension from the adater if need be
Morse is faster than texting!
JamesC
Community Manager
Community Manager
mross12,
JamesC
Discussion stats
  • 3 Replies
  • 6350 Views
  • 0 Likes
  • 4 In Conversation
