Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo Baby Monitor ABC1000 microphone not working
Reply
Discussion stats
  • 2 Replies
  • 2844 Views
  • 0 Likes
  • 2 In Conversation
Deepal73
Hi Guys
I purchased and Alro Baby Monitor ( ABC1000). Connected it through the app works every thing works well but not the microphone audio detection. I can stand in front of the camera and make noises but when I go to view the recording no sound and only movement notifications are sent to my phone. Even in live stream there is no sound. I have tried resetting the camera, deleting the app and re installing the app, reconnect the camera, basically I’ve tried everything to no avail. Help would be greatly appreciated as this is a feature is essential for monitoring the baby.
Thank you
2 REPLIES 2
TomMac
Guru Guru
Guru
Verify that the issue is with the unit instead of the phone/app by testing via a computer ( https://arlo.netgear.com/ )
this way you will narrow down the scope of problem and can either contact Netgear Support or return if able
Morse is faster than texting!
Deepal73
Sound still does not play on PC in live stream or on recorded clip. Would you recommend I return the camera?
Discussion stats
  • 2 Replies
  • 2845 Views
  • 0 Likes
  • 2 In Conversation
