Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
ARLO GO VS RACCOON
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
A raccoon successfully unscrewed my arlo go from the tree and pulled the skin off and ate it! I ciuldnt find the securing white piece that screws up into the cam to tighten it. Does anyone know where to purchase more? Thanks!
Labels:
- Related Labels:
Installation
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Kewl!
Any hardware store should have a selection of metal and nylon 1/4"-20 nuts. Make sure to get a small one if using the power plug.
Related Labels
Accessories
1 -
Arlo Go
1 -
Arlo Mobile App
65 -
Arlo Smart
12 -
Before You Buy
180 -
Firmware Release Notes
6 -
IFTTT (If This Then That)
2 -
Installation
124 -
Modes et règles
1 -
Online and Mobile Apps
66 -
Service and Storage
71 -
SmartThings
4 -
Troubleshooting
630
