Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Enjoying the NEW Arlo Go. Two questions:
1. What options do I have to buy additional cameras to compliment Arlo Go? Can I order the Arlo Pro and use the Arlo Go as the basestation or do I have to order addtional Arlo Go cameras only?
2. If I have a website of a golf course, is it easy for customers to link into the Arlo Go to check current weather conditions? Do I just copy/paste the URL from the cloud into a section of my website?
Thanks everyone and Thank You Arlo for staying progressive and innovative.
TK
Solved! Go to Solution.
Labels:
- Related Labels:
Installation
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The Go is a standalone product. Nothing connects to it nor will it connect to anything else.
For others to access it, they would need to use the app or a browser using communal credentials which could be an issue. You could use a web link to point to the Arlo website but they'd have to log in like you would. To keep things safe, you would need to set up a friend account using an email address that's likely not used for anything else. A bit clumsy but could work.
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Related Labels
Accessories
1 -
Arlo Go
1 -
Arlo Mobile App
65 -
Arlo Smart
12 -
Before You Buy
180 -
Firmware Release Notes
6 -
IFTTT (If This Then That)
2 -
Installation
124 -
Modes et règles
1 -
Online and Mobile Apps
66 -
Service and Storage
71 -
SmartThings
4 -
Troubleshooting
632
