- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I just bought a brand new Arlo Go. While plugged in, my Arlo Go works perfectly. However, it goes "offline" when I unplug it from the power adapter. This camera is supposed to be used off the power grid, and thats how I intend to use it. What am I doing wrong, or what's wrong with the camera?
PS - Battery is fully charged and is brand new.
Solved! Go to Solution.
- Related Labels:
Troubleshooting
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I figured it out. The battery terminal connectors on the inside of the unit were not making full connection with the battery. I simply bent them just enough for them to make full connection. The unit is up and running fine now. Thanks for the input!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Pull the battery pack and then replace...
go into settings and check if camera LED status is turned on ( lights blue when battery is fully charged)
(can take about 3 hrs to fully charge )
if it drops when the plug is pulled, it appears to be a power issue...tho the battery should be charged on delivery some have been lower then normal at time and need charging
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have already pulled the battery pack several times. LED will not even blink when unplugged. Battery is fully charged (charged all last night).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
did the LED show blue ( if toggled on in settings )...may be a bad battery
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The LED never blinks when unplugged. The camera will not give me the option to turn it on/off unless it is plugged in. However, when plugged in, it works perfectly. Is there some kind of setting that you have to tell it to work off the battery?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It sounds like you have a BAD battery....
If the battery is fully charged AND the settings for Camera LED is on the led on front will should blue ( full charge )
There's is nothing else to turn on , if the battery is good it will work when the plug is pulled
Contact Netgear Support ( bottom of page ) or exchange if able
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Accessories
1 -
Arlo Go
1 -
Arlo Mobile App
65 -
Arlo Smart
12 -
Before You Buy
180 -
Firmware Release Notes
6 -
IFTTT (If This Then That)
2 -
Installation
124 -
Modes et règles
1 -
Online and Mobile Apps
66 -
Service and Storage
71 -
SmartThings
4 -
Troubleshooting
630
