Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Will the arlo batteries work in the go model?
Solved! Go to Solution.
Labels:
- Related Labels:
Installation
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The Arlo Go and Arlo Pro batteries are physically not the same size and are not compatible with each other.
JamesC
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
They're the same size except for length so theoreticlly any of these batteries should work if they physically fit. The capacity varies so battery life will, too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
JamesC
Related Labels
Accessories
1 -
Arlo Go
1 -
Arlo Mobile App
65 -
Arlo Smart
12 -
Before You Buy
180 -
Firmware Release Notes
6 -
IFTTT (If This Then That)
2 -
Installation
122 -
Modes et règles
1 -
Online and Mobile Apps
66 -
Service and Storage
71 -
SmartThings
4 -
Troubleshooting
629
