You can connect your Arlo camera to a hidden wireless (WiFi) network (one that does not broadcast its SSID).
To connect your Arlo camera to a hidden network:
You need to know the name (SSID) of the hidden network. If you don't know the SSID, access your router's user interface to determine the SSID.
- During the Arlo camera setup process, enter the hidden Network Name (SSID), then enter the password for that network.
- Click or tap Continue to sync the camera.
- Follow the onscreen instructions.
