The Arlo Community
Learn, explore, ask questions, and connect with our community of customers and experts.
TKB Breadcrumb
How do I create a new mode for my Arlo Q and Arlo Q Plus cameras?
To create a new mode:
  1. Launch the Arlo app or log in to your Arlo account at arlo.netgear.com.
  2. Click or tap Mode.
  3. Click or tap the device that you want to create a mode for.
  4. Click or tap Add a Mode.
  5. Enter a name for the mode and click or tap Next.
    The Trigger Device page displays.
  6. Click or tap a device and Next.
    Note: If you have just one device, your device is preselected.
  7. Click or tap Next.
    Note: If you want to create a mode that does not activate when motion or audio is detected, unselect the triggers.
  8. Set the motion sensitivity and the motion detection zones.
    Note: You can use the sliders to adjust the sensitivity of the motion sensor. To specify motion detection zones, click or tap Create Activity Zones.
  9. Click or Tap Next.
  10. Set the audio sensitivity and click or tap Next.
  11. When prompted, specify what you want your device to do when motion or audio is detected and click or tap Next.
    Note: You can select Record video, Take snapshot, or Do nothing.
  12. When prompted, specify how long you want your device to record for when motion or audio is detected and click or tap Next.
  13. Select the type of notifications that you want to receive and click or tap Next.
  14. Enter the email addresses that you want alerts to be sent to and click or tap Next.
    The Summary page displays.
  15. Review your settings and click or tap Save.
    Your new mode is saved.
by ChristineT Administrator on ‎2014-12-14 10:05 PM - edited on ‎2017-02-13 12:32 PM by OnlineX Admin
